  1. I have a video with 4 audio languages.
    I need to author the DVD menu with the native language names (like Wikipedia style).
    But I didn't find any way to edit the language menu text.
    Is there a template of even other software allows to do this?
  2. I found a way by Apple DVD Studio Pro, which is discontinued and it was for Mac OS only.
    http://www.suitetake.com/2009/03/16/multi-language-dvds-so-easy-grandma-can-do-it/
    I need a solution for Windows, please.
  3. Make a new project in DVDStyler without a template. Delete the initial VMGM menu and use DVD -> Add -> Menu to add a VTS menu. Double click the menu and import some menu background.
    Add video/audio
    Add some buttons to the menu and use drop-down menu to select corresponding audio language.
  4. Thank you for your help.
    But I don't have normal video chapters,
    I just have one video with 4 audio files for those 4 languages.
    Any other suggestion?
  5. I may not understand but like attached?
  6. You were right, your your two explanations are same.
    Thank you for this wonderful effort.
    I followed your steps in the latest version of DVDStyler (3.0.3) but after creating the DVD iso file, the menu is not working.
    I started over from scratch more than one time, but I got not responding menu or even player!
    DVD Flick v2 did it smoothly fine, but there is no option to edit language menu text.
  7. Originally Posted by videobruger View Post
    ... like attached?
    I just want to thank you again.
    It's a great tutorial, I followed your steps again and fixed the error.
    I think that DVDStyler has a problem with WAV format,
    so I converted them into MP3 and it just worked fine.
    I noticed that it takes too much time for transcription, about 3 to 5 hour per attempt!
